Request option or capability to stop panning while in Live Stream" mode
I’m not exactly sure what you’re asking. From the live stream, you can tap the “more” button and then turn off Motion Tracking and/or Pan Scan. With those options off, the camera will not move unless you tell it to.
Thank you for your rapid response. I am looking for an override option where you temporarily disable Pan Scan while in the Live View window without having to go through multiple menus to disable Pan Scan.
So, as it is now, you tap More then you tap Pan Scan. Two taps. Not multiple menus. You are asking for it to be one tap instead? Given the limitations of available screen space, I don’t see that happening.
