I have had my 3rd Wyze Cam V3 fail due to a foggy lens. Because this one V3 is a year old and was given as a replacement the original V3 that got a foggy lens a year prior Wyze wouldn’t replace it. They did give me a $10 coupon that I used to help buy a Cam OG in the hope it will not get foggy is a year like all my V3 do.
But when I put it outback in the same spot my V3 was it wouldn’t maintain signal with my Wifi. I then took on of my other V3s and put it out back and moved the OG to replace the front of the house V3. But even in that spot the WiFi signal and over all connection is much worse than the V3.
Do I just have a lemon OG or are all OG just worse at WiFi than the V3s?
