So my thoughts so far are it’s pretty good for the price. BUT there are a couple of things that should be fixed - for example I figured out that if you tap it on the top to try and get things inside loose to empty out then it won’t turn off or back on unless you then tap it from the bottom for some reason. Also, if you’re vacuuming up pet hair it has the same flaw as early Dysons did in that things get wrapped up around the cone toward the top of the canister and there’s no way to get in there easily to get the stuff out.
But otherwise so far I’m happy with my purchase. It wasn’t meant to be a main vacuum for me anyways and just used for light\lighter duty. I have two Dysons (a stick and a big ball) for the heavier work for a reason.
