Multiple base stations w/ethernet splitter will not work. Only blinks blue light and causes existi g base station which has always worked perfect to blink. Help! I dont have any other ports on my google mesh system or the modem to connect ethernet to. Only can using splitter.
Are you using an Ethernet switch, or a splitter. Never use a splitter, they won’t work for anything. You must find a powered ethernet switch.
Using a splitter. Will try the ethernet switch. Tha k you.
