If i get the appropriate cables, can I mount the V3 spotlight remotely from the camera using the supplied cable splitter to power the spotlight? I’m thinking of a 25 foot cable run. Any tips or experience?
Make sure you use a data capable cable for both runs to the camera and the spotlight. Not sure if 25ft will work? Really depends on how much data and power is lost on the trip.
Thank you!
