I’m trying to write an Alexas routine that sense wnen my motion detector “senses motion”
When I go into the Alexas app to select the motion sensor…it is there…BUT when I select it I get a “not supported message”
Trying to sense when the mail has arrived…any ideas??
In your Alexa app, go to Skills, then find and disable the Wyze skill. As soon as it is disabled re-enable it (log back in using your Wyze credentials) and you should then be able to create a routine that uses the sensor.
Where in the routine process does it say not supported? You said you were able to select the motion sensor, so I wonder if it’s another function that isn’t supported.
Edit 30 mins later/. I made a routine earlier to test this to try and replicate, well I forgot to delete it and it just triggered and my Alexa device was full volume and it scares the crapola out of me. It works!
Thanks for the info. I know you said your relogged into the Wyze skill in Alexa, but have you deleted and readded the motion sensor device in Alexa? If you choose a different Wyze device do you also get the not supported? Or is that just the motion sensor that does this?
The normal communication pathway would be sensor to bridge, bridge to camera, camera to router, router to app/Wyze etc and then reverse. In practice the camera with the bridge seems to work up to about 30 feet from sensor with no intervening walls etc, when you add obstructions or walls or large masses of metal etc the range drops quickly.
I have 3 motion sensors, the farthest gap from sensor to bridge is about 10 feet.
