Just installed a motion sensor to trigger my camera. when I try to access the playback from the generated clip…I get “no microsd card inserted” message. Viewing the playback from the camera is no issue.
I gather when you inserted the SD card you heard that annoying chime indicating that it was discovered?
There is no issue with the SD card outside of this occurrence. I can access it remotely when away from home, I can review video from any time period. Before I installed the motion sensor and the hub, there were no issues at all. This issue is easy to work around; I just access directly from the camera. I just am unable to access the video playback outside of the 12 second clip that is generated from event.
