WYZE floodlight v2 not reliable. Might have to use NVR wired to solve, WYZE been a headache.
With WYZE using a poorly implemented cloud methodology and blocking serial numbers from connecting causes camera to go offline nad never able to be reconnected. How can we independently overcone this limitation? if my cameras get knocked offline by WYZE cloud system, and I cannot reconnect them withoutvthem clesring the serial numbers, how can I have reliability?
I wonder if what you’re trying to describe is what’s been discussed in this topic:
Your mention of “blocking serial numbers from connecting causes camera to go offline nad never able to be reconnected” makes me wonder if you’re experiencing the issue described in that topic, which appears to be that the latest firmware update for Cam Floodlight v2 causes problems with the camera connecting to a hidden or non-broadcast Wi-Fi SSID.
Having the same issue with the floodlight V2, it’s getting annoying. I go up there manually reset for 10 seconds maybe 12 days later it’s off-line and then I take the ladder out and do this over again. I’ve submitted a ticket. None of the had the pro version in its place and it had no issue but having to Manually reset it and then add it back as a device in the app is annoying and not to mention is defeats the purpose of having this device in the first place I have gone through all the troubleshooting and I have everything up-to-date and definitely has to do either with something With the design of the hardware or their firmware issues because this is ridiculous. I have a several other other products and they work flawlessly and they’re actually further away from the router.
I even added the routine or whatever they call it automation process thinking that oh I’ll just have it power cycle itself every day just in case it gets a glitch while obviously has to be. The automation has to be sent from the server in order for it to reset it’s not something that it keeps in its memory And in case of disconnect so very disappointing. I thought oh OK. I’ll just have a power cycle every day if it needs to reconnect just in case it freezes so I don’t have to get the ladder out well nope that didn’t work.
