Missing option to set cool down on Cam Pan cameras (v2 and v3)
I have three cam pan cameras setup, two are v3 and the other is a v2. I have Can Plus enabled for all three and an SD card installed for continuous recording. I have event recording enabled for pets only and notifications enabled for the same. Unfortunately I cannot find an option to set a cooldown period for the event recording/notifications. As a result, as long as the cameras detect an animal moving, they send constant notifications. Is this a feature or a bug?
There’s no way to set a cool down, but you should only receive a notification once for every event. If the events are really short, you will receive constant notifications. Try raising the sensitivity so the events continue, rather than stop and start a new one.
That’s helpful, thank you! Instead of messing with it further, I just cancelled the cam plus subs on all cameras. Since I have SD cards installed, I can still access footage and get basic notifications. Not ideal, but better than the alternative.
CamPlus Lite will work with the V3s and V2s. You can get person notifications with that with a free CamPlus Lite subscription.
CamPlus Lite is NOT compatible with your two Cam Pan V3. It is compatible with your Cam Pan V2.
Missed the PanCam…
:face_with_hand_over_mouth:
Putting the Cam Pan v2 on Cam Plus Lite would give that camera a 5 minute cool down between Event Video recordings.
Without the ability to set a custom cool down period, the Cam Plus subscription is not going to work for us. Adjusting motion sensitivity doesn’t help since it just causes the cameras to miss events. I decided to cancel the subscriptions for all cameras and, instead, I’m going to rely on SD cards for play back. We still get the alerts with a hard set 5 min cool down which is better than what was happening with the Cam Plus sub active. Hopefully wyze decides to add a custom cool down option for all cameras and services in the future.
