I have 7 cameras yet the Home Monitoring Settings for Security Cameras only list 5 cameras as available. How can I get the other 2 cameras on to the list of available cameras so they can be selected as security cameras? Currently only 2 of the 5 available cameras are selected.
At this time HMS only supports 5 cameras.
I would like to make the selection of the 5 cameras from my 7 cameras. But 2 of my cameras are not listed as available.
Gotcha, thank you for the additional info.
What camera versions?
Do they have Cam Plus licenses?
Not sure but is that a requirement to be available as a security camera?
I have 5 of the 7 cameras on Cam Plus but of these 5 camera only 3 of them are on Cam Plus and 2 that are listed as available are not on Cam Plus. So 2 of my Cam Plus cameras are not listed as available in HMS. And these 2 are the new Cam OGs.
Thank you for the additional information. I reached out to @spamoni4 who looked into this for me.
Cam Plus is not needed but, it appears as if the OG cameras do not show up in the list of cameras to add to the HMS system at this time.
You are correct. I tested with My V3 Pan Cam and was able to add it to HMS without Cam Plus.
The PanV3 cams were added to the Security Cam list on the last App update release shortly after the cam was released.
The OG cams are not currently in the Beta App being tested now. I would suspect that the next Beta build cycle will see the introduction of the OG cams into the Security Cam list.
