yes , cam pan v1
I have no experience with a cam pan so I canāt help you out with their settings or behavior.
im thinking buy a cam v3 for exterior if i cant fix the problem,
maybe v3 works
Yes I just read the note at the bottom, they paused it because it caused issues, did not read that earlier. Change the name of your post from (outdoor cam) to (cam pan) you will get better help than from me from members who own that type of cam. I only have V3 and WCO cameras.
Current firmware that I have is 4.10.8.829
That version is not listed on the release notes, is it listed someplace else? @kae4560 you should have stated you are using the Beta version still in testing so I didnāt have to look for it.
You should be able to run your updates from the app,that the only way we do
See above, it is BETA
Have no clue we have a team of techs that do all the updates, etc.
Thanks,itās worthless to me,our site guys do all the updates, thanksā¦
