Tried micro sd in both base stn and outdoor cam, no luck. Tried Wyze brand micro sd. formatted successfully (yay) in base stn, download and send event attempts bring immediate “operation failed.” Base stn running thru Ethernet bc it won’t accept wifi. Ideas?
Can’t help you with the outdoor cam, but wanted to let you know it’s SD, not SB. SD is short for Secure Digital and we are using the Micro size version. So it’s Micro Secure Digital or uSD.
Right, thx. My heab was somewhere else
I am using cheap 32GB MicroSD cards in all 3 of my V3 Outdoors and they work without issue.
Not sure where you are located, but these are the ones I got from Amazon Canada.
Haven’t failed me yet.
