Manually adjust camera of pan 3
Can I manually control the direction of the camera?
Yes, you just use the arrow buttons on the camera live stream screen as indicated by the red arrow:
Yes, as carverofchoice showed in his post… just remember, if you have waypoints set, it will revert back to the 1st waypoint setting after about 15 seconds.
