Manual video recording shows corner image
Hello,
When I manual record and go to the album, it shows the corner of the ceiling instead of the whole image. It’s not zoomed in either. Any idea how this can be fixed?
Have no clue
When I record in real live time, it’s fine. It only happens when I go back and try to record.
Sounds like a still unresolved bug affecting V3s that are set to 360p resolution (not SD or HD). If so, the work-around is to switch your live view to at least SD resolution.
Let us know if this fixed it for you. :slight_smile:
You are amazing! That did the trick when I changed 360 to SD! Thank you so much!!!
