Is there a way to make the Sense HUB sec alarm LOUDER than the setting allows. We can barely hear it and want it to be LOUD.
What firmware version are you on? In September of last year a firmware update significantly reduced the volume of the hub. It was reported and took until the April update this year to fix it, but nowhere near the original volume.
If you firmware is older than (.249), and your hub is working, I would recommend not updating yet. Read thru the forums about Hub update firmware first. Many have bricked hubs because of updates.
FW update notes:
Summary
4.32.9.249 (April 25, 2022)
Improved Ethernet network connectivity
Enhanced Wyze Sense Hub audio volume
Fixed a bug that prevented the Entry Notice from playing when a door was opened
Other bug fixes
Note: This firmware does not address the sensor connectivity issue some are experiencing and we’re continuing to work on resolving that issue. Thank you for your patience.
4.32.8.246 (April 8, 2022)
Security improvements
4.32.8.213 (March 2, 2022)
Improved network connectivity and reporting accuracy
Bug fixes
Note: This firmware is halted due to reports of issues such as sensor connectivity problems. If you are experiencing trouble with your Wyze Sense setup after updating, please reach out to Wyze Customer Support.
4.32.7.177 (December 8, 2021)
Network reliability and performance improvements
Bug fixes
4.32.6.142 (October 18, 2021)
Fixed a bug that prevented some users from saving the entry sensor chime sound in Tune Settings
Fixed a bug that caused some users to have their entry sound off by default
Fixed a bug that caused a decrease in Wyze Sense Hub voice prompt volume from last update
Fixed a bug that caused difficulty in switching modes for some users
Fixed a bug that caused an operation delay after switching networks for some users
Known Issue: There is a user interface bug that makes it look like hub volume has not been changed to the low or mid settings. Upon re-entering the Hub Settings page, the display will revert back to the previous setting. The actual volume will be changed and saved.
4.32.5.92 (September 22, 2021)
Fixed a bug that caused some hubs to turn off immediately after the hub is unplugged from power
4.32.5.80 (September 8, 2021)
A PIN is now required to switch to enter Disarm Mode from the keypad
Added a fast beep for Entry and Exit Delay
Fixed a bug that caused some delayed false alarms for some people
