What you’re suggesting seems almost like a Wishlist request, but it’s not something I’d expect Wyze to implement (at least not any time soon) for at least two reasons:
As far as I know, the Wyze app isn’t officially supported on macOS even though it can run on some Mac devices.
My understanding of this type of application window handling is that it’s typically done by the OS (or a desktop environment [DE] and/or window manager running on the OS) and not exactly (not always, anyway) by the app itself (even though you’re seeing that option in VLC’s UI).
When I run VLC on Ubuntu Linux (with GNOME as the DE), I do see an “Always on top” option beneath “View” in the menu, but if I right-click the application’s title bar I see that I can also select “Always on Top” from that pop-up menu, and that’s a function of the DE. I’d look to see if your macOS version has a similar feature, because if I do a Web search for macOS keep app on top, then I get results that link to pages with advice like this:
One of the simplest ways to keep a window on top of others on your Mac is to use built-in features that are already available in macOS. While these features may not offer as much customization or flexibility as third-party applications, they can be useful for basic tasks and scenarios.
One such feature is the “Float on Top” option, which allows you to keep a specific window on top of all other windows on your Mac. To enable this feature, simply open the window you want to keep on top, click on the window’s title bar, and select “Float on Top” from the drop-down menu.
I’m not a Mac user, so I can’t vouch for that advice, but I’m also seeing suggestions for third-party apps to achieve this effect, so in your case I’d probably be looking for a built-in OS feature or a third-party utility to manage the app window rather than wait for Wyze to implement something like this.
Regarding other things you’d like to do with the app specific to macOS, I wonder if @habib might have any advice. I think he uses the Wyze app on a Mac quite a bit. Regarding the floating bit, though, I’d still wonder if you’d be better off looking within the OS itself or trying a third-party solution to manage that feature for you.
Actually I don’t, I only use it occasionally and mostly to demonstrate to others that it works on a Mac. I use the phone and the iPad mainly. As for floating window, not sure if it works, I might try it on the weekend as I need to update it first to the latest iPad version.
It should be just checkmarking iOS for Apple Vision Pro. No extra code! And people would have $3,500 glasses for other reasons. Although for two camera and, little code, can build a 3D stereoscopic viewer.
