I got that special firmware, it didn’t fix my issues!
4.50.16.6722
Good luck to others!
4.50.16.6722
Will do.
Interesting and sorry to hear that James.
Same here. They said they pushed it out, but I’m still having the same issues. They want me to go through a bunch of troubleshooting steps - on a ladder of course - but I’m not optimistic. I did all of that before. What’s sad, is that in the message that told me they sent out the patch, they included instructions for what to do if the patch doesn’t work. I wonder why? LOL.
You should be able to confirm the version of firmware on your devices. Within the app, head to account, firmware update. On that page you will find a list of your devices. Each device will list the latest firmware version available, along with the current version on the device.
Shame they keep giving hope to people with this “special firmware”. So far there is nobody on this forum that has had their issues resolved. I guess it is neat to feel special, but sucks to be let down by WYZE yet again. I try to avoid emotional rollercoasters myself.
I have two wayze pan v3s, one downstairs and one upstairs. They both worked fine for a year or more and sometime late 24 - mid-25 one of them stopped recording to the SD card and having the issue you’re describing. I am using two a 128 GB PNY elite x microsds formatted exfat. Both of them work fine in the downstairs camera without an issue but both of them on the upstairs camera I will freshly format it on my computer put it in it will work for one or two hours and then it just stops it will say I’m only using like .79 GB out of the 116 GB. I can pull the card out put it on my computer and I can see the folders with the videos and their normal all up until the end and then they start skipping numbers. I do notice that the times they’re created are in the future. And eventually the last two videos are corrupted and you can’t open them I can reformat the card put it in the downstairs one it works fine indefinitely, I reformat it again put it in the upstairs one and it does the same thing works for a couple hours and then stops. I can reboot the camera from the app and it will start working again maybe for a few minutes maybe for an hour and then stops and half of the time I reboot it, it doesn’t see the card at all tells me I need to format but the format in the camera doesn’t work at all, but works fine on the other camera and works fine on the computer.
Mac D03F27B9CF6B
Firmware 4.50.16.6242
Activated 9/3/23
The newest beta firmware 4.50.16.7064 actually IS doing something different for my Pan V3 cameras.
They’re not back to working 100% as they should, BUT they do recognize SD cards again, they can format the SD card, and they record to the card…sporadically
How do I get it?
Here is info on the Wyze Beta program.
https://support.wyze.com/hc/en-us/articles/360032458951-Become-a-Beta-Tester
We have been waiting a long time to get the SD card issues on the Pan Cam V3 resolved. Wyze needs to get this fixed if they want to keep their customer base. I do not want to become beta tester, but would like access to any potential firmware update that could possible fix this ongoing problem.
SD Cards are no longer recording on any of my v3’s or v4’. I went this morning to check and not one of them even recognize the SD Card.
Hi
“MicroSD Card Not Supported”
One of my Wyze v3 cameras no longer supports SD cards. Started several months ago. Otherwise camera works fine.
Tried differen SD cards same problem.
SD cards work OK on PC and on other Wyze V3 cameras.
Mac: D03F27880C47
Mmodel: Wyze 2Cam V3
Firmware: 4.36.16.6114
SD Card: SunDisk Ultra 34GB (several); SunDisk High Endurance 64GB; SunDisk Extreme 64GB
Camera worked fine for 2 years+.
This camera cannot format SD cards.
I don’t think that it is due to firmware as other working cameras have same firmware versions.
Error messages:
Accessing Card from events: “MicroSD Card Not Supported”
MicroSD Card: "No MicroSD card found.
Ihad this is he with 2 pan 3s and multiple brands and sizes of sd cards in them.
Y’all replaced to first one, then the second pan3 started doing it.
Doesn’t seem to be rhyme or reason and it’s different brands and sizes of cards. All do the same thing.
No video playback
Sometimes says no card
Sometimes say format to fix, so I do and nothing changes
I have two 2023 Wyze Cam Pan v3s, and neither of them will recognize any SD cards. I have brand new SanDisk High Endurance 64gb microSDXC cards. I formatted them to exFAT at 32kb on my computer, and my computer DOES read the new cards correctly. When I insert the new cards into the Wyze Cams, there isn’t a ding-ding sound or anything. In the app, the camera indicates that a new SD card has been inserted but isn’t recognized. If I choose “format,” nothing works. The cards are not supported AT ALL.
The cameras are up-to-date on 4.50.16.6242.
I’m so terribly disappointed given how much time and money I’ve invested in Wyze for this issue to be so widespread and still have zero answers or solutions.
exFAT is wrong. Use FAT32.
Or erase the microSD card using DiskPart and let the camera format the card.
For me, that (Diskpart) was the only way to get my Pan V3 to still use my 32 GB microSD card.
I’ve since gotten rid of all my Wyze cameras and switched to TAPO cameras. They have no issues with microSD cards, you don’t need a subscription, and they don’t really cost any more than the Wyze cameras. Plus, their support responds pretty quickly if you have any questions.
I have tried FAT32 and exFAT on the old 32GB cards and the new 64GB cards. I erased the cards entirely using DiskPart per your suggestion. I have let the app try to format the cards dozens of times. I have turned off the cameras and fully shut down the app numerous times to reboot them. The cameras do not–and will not–recognize any micro SD cards.
Good post BFF. I may have to check TAPO out. I’ve been working with their customer service now for a couple of months. As I respond to messages, there is a new service tech involved so not much continuity. They do seem to have a process for troubleshooting these SD Card issues though - clearly its a common issue so they have developed procedures. I have 5 cameras acting up on micro SD cards, and none of the trouble shooting worked until I installed one of the Wyze microsd cards which they sent me. That finally worked. I had tried brand new SanDisk cards, which also failed. I can only assume that they only tested out their recent software “fixes” on the Wyze micro disks. Sadly, all of the cameras worked find on San micro cards for years until they all fell apart. Oh well, good cameras up to then but they must have broke something.
Jaggy - I’ve been exchanging messages on my cameras with Wyze tech support for a month or two now. They finally have 1 of my 8 cameras working, which boiled down to version 4.50.16.6722 software (newer than yours) and a new Wyze card. (My new San Disk microSD cards also did not work. ) If you have the patience and tenacity to hang in there, I did receive some value from their tech support service. Not done yet though.
Just updated to new firmware. The SD card issues still remain. PanV3.
I’ve been seeing the “No Video Available” error on and off with one of my Cam Pan v3s, using multiple different SD cards. Typically, formatting the SD card using a computer (not the camera itself) alleviates the issue for a little while, but after a few days to weeks the recording stops working again.
Camera details:
Thank you to the Wyze team for reaching out to customers and investigating this issue!
