Login button not working on 2.7.29 with iOS 13.3. Any ideas? I deleted the Wyze app and reinstalled it.
Still can’t log into the app.
But I can login to the forum/community. So it’s not a password issue.
I get: “Failed,code: 1001” notification when trying to login.
Welcome to the forum! The past couple of days have had issues with the login system. Keep trying and if you still are not able to login with your credentials you should contact Wyze Support
I am running ios 13.3 + 4.9.5.36 and it’s works fine. Maybe uninstall, reboot, reinstall and try again…
It finally cleared up. It seems like it was some type of Wyze login system problem. Seems like I’m good to go now.
