I’ve tried my “pan” in two homes (1,400 & 1,900 sqft) and have basically line of sight connect ability only from both routers. I have no issues with signal strength on iPads & laptops.
It works fine until a wall gets in the way. Any ideas?
You could try changing WiFi channel on the router. If you have the technology (a WiFi analyzer app on your smartphone, or a scanning feature in the router), do a spectrum scan and pick the least busy channel.
If that doesn’t help, get a WiFi repeater, and locate it half-way between the cam and the router.
