Hello, I encountered a problem and I want a solution. I switched the setting of the lights to the Wi-Fi, but the network was weak and the installation was not completed, but when disconnecting the Wi-Fi, the lights went out and it no longer works even together with the factory setting. The type of lighting bulb color
I don’t quite understand a lot of what you said, but hopefully you can:
- Put the bulbs in a single-socket lamp close to your router, one at a time
- Cycle power to each one 3 times. That should make the Bulb start pulsing, showing it is in pairing mode.
- Then hopefully you can re-add each one to the app, and
- Put them back where you had them installed.
