You need to join the beta program, but this is supposedly fixed in the current app.
Similar issue to OPās. My router died and had to replace it. Everything was going swimmingly until the last 4 or 5 devices. (I have many LOL). I found that my new router was limiting the number of DHCP devices connected. I bumped that number up and BINGO! Hope this helps someone.
Hey, Did you buy a Wyze router? You can change the device limit number on that router? I thought it was fixed a 75?
Seventy-five is not enough for me. I had to look around to find some that had at least 150 better one I use is 200 now.
But yes, that is a problem. I suspect thereās many people with offline/diconnected devices that donāt check their router to see what its limit is.
Mine is a Linksys Router. I honestly didnāt know Wyze had routers.
This is sad I can only downgrade to 2.7
This is sad I can only downgrade to 4.7
