Lamp socket question
Does the the Wyze lamp socket retain the light bulb state (on/off) after recovering from power loss?
For example, if the light bulb was off and the power went off and back on, would the light bulb stay off? Or is there a default state for the bulb after power loss?
ATM, using V3 firmware 4.36.8.15 and socket firmware 0.9.0.27, it appears the lamp is on after all power outages until it is next told to turn off.
