Just got my vacuum, so far so good. Made a good map of my house.
NOW—How do I block of areas so that the bot doesn’t clean there??
thanks
rich
thanks
rich
There is a shaded square in the bottom right under the map. Click that and it takes you to a screen where you can add virtual walls.
got it thanks so much
Also the power on light is still on after even though the bot is 100% charged. I read the booklet and it seems the bot should be in sleep mode. If so will the power lights still be on?
