Hello,
I’ve been using the RTSP Firmware on my V2 Wyzecam to live stream wild owls that live in an owl box on my property. While it mostly works, I am running into some issues below:
-Feed gets glitchy when there is a large amount of movement
-Feed glitchiness gets worse when night mode is on
-Sound is always glitchy
Also:
-My signal strength seems to be good (Though I am using a mesh system for wifi)
-Problems exist even if I just view the feed on VLC and not streaming, so I dont think its the stream software I am using (Streamlabs OBS)
Does anyone have any ideas on how I can make things preform better or what the cause might be? Is it the RTSP firmware?
If you view my twitch stream, you can most likely see what I am talking about. Ill post the link below. Thanks!
https://www.twitch.tv/hoothouselivestream
