Is Wyze Router Compatible with Eero Routers?
In which way are you asking?
Personally, I would replace the Eero Router with the Wyze Routers. I do not believe you can mix and match them as Nodes.
However, I am sure you can add them to a port on the Eero or a switch set them up as its own network.
See the note that Wyze routers support only 50 devices per node? And no hint if the app would allow manual manage to shift some device to a second node. (That’s the problem I had with eero routers, 75 device limit and could not push them to the unserved node.
