Some and it might be more complicated than that anyway, so feel free to ignore the following, but since I was asked, I’ll share some of what I’ve gathered recently from public discussions:
I can’t say this is a perfect way to tell, and this uses an old list they pulled from the API, but Docker Wyze bridge shared a list of cameras that were compatible to work with it, and some that weren’t. I would guess that in general, most everything on that list are the primary cameras that it is easy to copy features between, and everything not supported uses a different SDK and may not copy exactly the same way.
The issue might be complicated a little more though. Back when that list was created, it was based on which cameras used TUTK for authentication (supported) vs which didn’t (not supported) [Gwell Cameras using the lotvid SDK?]. But since then, Wyze has taken some of the cameras on that list and switched their authentication from TUTK to Agora. So I think now there are 3 different kinds of authentication because some of the old cameras never got a firmware update so they have still got to be running on TUTK, but some of the cameras that had TUTK were switched to Agora, and there are still Gwell-based cameras using something else.
So it also may not just be Linux vs FreeRTOS, or which SDK/Authentication, but then there are multiple Supplier/manufacturer partners for their cameras as well (at least 3 or more; and the model numbers usuall hint at this depending on whether they start with “HL_” or “GW_” or “ME_” recently), and the different suppliers might start with a different initial core firmware foundation between them before Wyze does their custom stuff? (I’m not saying this is how it goes, I really don’t know if there is a base firmware they build on top of or if they scrap everything down to their own custom code 100%, I only know they have multiple supplier partners and in the initial years, at least one of them had base firmware included).
But I did used to ask in every AMA when a new camera launched whether it was Linux or FreeRTOS. I remember one of them mentioned that generally, the cheaper and faster cameras ran FreeRTOS. The OGs were the first to run FreeRTOS. The Videodoorbell pro is also Gwell-based. The Duo Cam Doorbell & Window Cam have model numbers that start with “GW_” as well, so I am certain they are also Gwell-based and likely Free-RTOS, I think most of the battery cameras since then have been FreeRTOS as well to preserve battery life (but battery cameras are all unlikely to get RTSP support anyway since RTSP doesn’t work well with battery-powered devices since it usually needs to be running constantly which would drain a battery). But I’m not certain of the battery cameras using FreeRTOS.
I know that wasn’t SUPER helpful overall. I think the issue is complicated and I don’t want to give confident but false information when there are other variables that could impact it too.
In general I think anything with a model number starting in “HL_” is likely linux-based and likely to RTSP in the long run if it is a popular enough feature. And those with “GW_” or “ME_” are slightly less likely. But I am just making an educated guess and not speaking for Wyze. They could absolutely provide it for any camera.
A few examples of model numbers that might give us a hint:
| product |
model code |
| Battery Cam Pro |
AN_RSCW |
| Video Doorbell Pro |
GW_BE1 |
| Duo Cam Doorbell |
GW_DBD |
| Duo Cam Pan |
GW_DUO |
| Cam OG |
GW_*** |
| Cam OG Telephoto |
GW_GC*** |
| Window Cam |
GW_WC |
| Bulb Cam |
HL_BC |
| Cam v3 Pro |
HL_CAM3P |
| Cam v4 |
HL_CAM4 |
| Cam Floodlight v2 |
HL_CFL2 |
| Video Doorbell v2 |
HL_DB2 |
| Cam Pan v2 |
HL_PAN2 |
| Cam Pan v4 |
HL_PAN4 |
| Cam Outdoor v2 |
HL_WCO2 |
| Cam Floodlight Pro |
LD_CFP |
| Battery Cam Solar |
ME_BTC |
| Battery Video Doorbell |
ME_DB1 |
| Solar Cam Pan |
ME_WCO3 |
There could be some costdown iterations or other variations within those too (for example, I know that V2 cams actually have at least 3 different hardware versions and aren’t actually all the same)
A lot of the older cameras model numbers don’t have a prefix, but most of them would have a prefix of “HL_” if they did.
Cam v1
Cam Pan v3
Cam Outdoor v1
Cam v3
Cam Floodlight v1
Cam v2
Cam Pan v1
Video Doorbell v1
I think most of those were “HL_” based and running Linux and originally running TUTK.
I’m sure I missed a bunch.
Indoor Cam Pan - I’m not sure what that one is offhand or which supplier or prefix. I haven’t checked yet.
But the above list is a good start. I would guess most of the “HL_” cams get priority on RTSP because it should be easier to just copy over the same code from like-system to like-system. But some of the “HL_” cams got switched from using TUTK to now run AGORA, but I don’t think they all did since some of the cameras haven’t had a firmware update since the changes started happening. So maybe that will make a difference and I don’t know clearly how to tell which are stuck on which yet offhand. I just noticed that some were changed that way since it started showing up in my router logs and other people have been publicly reporting on it as well. Maybe that variable will impact which get it next or not.
Again, I don’t work for or represent Wyze. They didn’t tell me the things in this post. What I said is my logical deduction based on publicly available information, including out of context answers from past AMA’s, anouncements, and public shipping records and other various logical inferences. So don’t take my word for it.
But it’s interesting information that could be a lead if we really want to speculate about logical likelihood based on what will be easiest for them to do.
