Is there a way to change where the camera is facing when stored?
Is there a way to set a default position for the camera to be pointed even when you turn it off? I don’t want it to face upward when stored because of dust/moisture or bird droppings, as my camera is outside under a covered patio.
Welcome @poolboy610
What you can do is select Privacy Mode at the bottom of the Live Stream. This will turn the camera place the camera in Privacy Mode and point it down towards the base.
If you don’t see that, simply scroll the shortcut bar to the left or right
