Is my Wyze OG compatible with Wyze V2 battery powered
Will these work together on the same app with Alexa?
Welcome to the Wyze User Community Forum @gordn24! :raising_hand_man:
Can you provide some more details?
What compatibility between the two cams are you looking for?
What do you mean by “Work Together”?
I don’t have the Wyze Cam Outdoor v2, but I do have the OG S and OG T and both will stream to my Alexa App.
I was wondering if they all work off the same app
Yes. All Wyze devices are accessible and are managed through the Wyze app. Wize only has one app and it is the central management and viewing platform for all of their devices. Most Wyze cams can also be streamed through Alexa devices, but they cannot be managed there.
