Is it possible to maximize the screen in Wyze Webview? I see no option to maximize it. Thanks.
You can zoom your browser under settings. The live view will adjust to accommodate.
Okay, I do see a “full screen” option in Chrome, under the “three dot” drop down menu. So that does work thanks. I would prefer a maximize button on the Webview screen itself. But thank you.
There is even a zoom option. Should look like a minus sign square brackets and a plus sign. If you zoom to 125 percent or 150 for larger video or lower for more videos across the screen.
Thanks everyone for this update on zooming in and out.
In most browsers (on Windows), the F11 key will maximize the Tab to Full Screen (more than fill browser page).
I’ve noticed the only way to see the full view of the camera is to go to Full Screen. Full page chops off the bottom of the view. I do wish the view would resize properly.
