I just installed the doorbell pro, and moved to the Beta app. When I get motion detected notifications, I get the banners, but no vibration. I’ve checked all my settings, and there doesn’t seem to be any reason for it not to vibrate. Is vibration turned off in the Beta?
I do not use iOS so I will tag in some of the @Mavens as I know some of them do use iOS and are on the beta. As far as I am aware the phone controls the settings as far as vibration since there are none in the app, they may be able to help you resolve the issue.
i thought that vibration would have been in the phone settings as well, but my other apps vibrate on notification and the Wyze beta does not.
