IOS app to 4k external display
Hello,
I use the Wyze app on my Ipad Pro 12” connected to a 4K external display via usbc to hdmi. It works, but I cannot get the app to use the entire display. Is this even possible with the Wyze app on IOS 26+
VinceSH
Is it just the wyze app or the entire iOS that is small? Google seems to say that you need a displayport cable for that (which most TVs don’t support).
Since the ipad’s resolution is not 4k you’d probably also have to disable the internal screen or do an “extend” to the TV instead of mirror.
