iOS 2.5.45 and Android 2.5.28 Released!
At this time, the cameras are useless
Can even login at all.
They must have resolved issues. I can login. Get notifications and events
Indeed, it seems there were some morning gremlins out yonder on the left coast:
I tested out the beta app couple weeks ago, on a separate device , it screwed up my shortcuts my phone that was on 2.4.82 , I uninstalled the beta app from the other device then fixed everything on my phone running 2.4.82 ,so, for now I’m going to be sticking with 2.4.82 .
I guess that’s why I didn’t have problems today like everyone else
STRANGE TRANSITION???
Application teams in 99% of any professional organization would have been disbanded for such bad practice. You dont make such a change by relocating something in the front and moving it to bury it deep in the bowels of the application who knows where without some kind of MAJOR headsup. Or at least optional buy-in.
I cant turn off the motion detection alerting because now I cant find where the hell the buttons moved to so the cat is just chewing thru your storage space.
Can someone please tell me where this functionality has moved to or how to get off this “UPGRADE” from hell?
Does anyone know where my shortcuts got moved to? Cant turn off an automated schedule when Im home now. Phone is getting filled with alerts.
I HATE when app developers do this crap and just shove crap down your throat with no headsup. REALLY bad practice.
jstryker,
Within the “Schedule” section, it’s actually been rebranded as “mute/unmute” notifications instead of enable/disable. Still called enable/disable within the “Shortcuts” section.
Read up a ways in this thread and you will see that any shortcuts you’d had automated previously have been converted into scheduled tasks within the “Schedule” section of what is now called “Rules” overall.
Agreed that the rollout was clumsy, presumptuous, and a bit draconian.
So - what if I want to disable the scheduled event instead of UNMUTE. I dont want 500 captures in the days log becuase it was constantly recording and uploading to the cloud. I’d like to disable that with the short cut.
This is SUCH a bad manuvere - if I cant turn on/off without having to dig thru several layers of menus - I’d actually switch cameras which would be akin to chopping my arm off to satisfy an itch… but I REALLY despise poor rollouts- at any major company this would have been an immediate termination.
We apologize and I will share your feedback with the team. Thank you for taking the time to share your thoughts.
I am still recuperating from discovering your current pains yesterday… :slight_smile:
Pretty sure they will get this right in the end, but agreed that it was kinda harsh to simply convert shortcuts without a trace.
Bottom line is that you’ll need to re-create any shortcuts that you expect to toggle manually.
HOW DO WE GET THE SHORTCUTS BACK. ROLL BACK TO EARLIER VERSION? THE ORIGINAL WAS WORKING FINE PRIOR TO THIS MONSTROSITY.
Please advise how we can roll back to prior version and now that I know there are such poor scruples among app developers I’ll be looking to remove automatic updates from WYZE.
Thanks Secondary_2g.
Previous Wyze app version 2.4.82 download
I can’t say that this will work but you can try it.
Edit: Android Version Only!
Thank you Gwedolyn.
I dont expect a response from this app team in the near century since they didnt bother to care before the release - certainly wont give two hoots after this boondoggle.
In the meantime - can you please advise how I can roll back to the previous version that was working fine?
Thanks I’ll see what I can do with it.
You’re welcome. Hope it works for you. This is only for Android users.
Hey Gwendolyn,
While you’re engaging in those communications, you might also have them consider renaming “Add/Edit Rules” to something like “Automation”, “Customization(s)”, “[Power] Tools”, “Wizards” (Wyzards?), or something that more broadly encompasses what are now (3) sub-categories. Shortcuts, in their current incarnation, aren’t really rules per se. Another approach might be to bring back the Shortcuts section as it was and place Schedule & Triggers within Rules separately. Acknowledged that this might grow the root menu +1 unnecessarily.
I was also thinking that it might’ve been (or still be) helpful to have included a demo/tutorial overlay screen for the overhaul - similar to the screens one encounters after first installing the app. This could’ve significantly softened the blow for many folks.
Additionally, it would’ve been helpful had shortcut buttons been preserved but stripped of their scheduling properties… the demo screen could’ve directed folks to the newly implemented Schedule section for the automated portions.
Just my picyaune $0.02 worth of inflated fiat currency… :wink:
Tried again. Still won’t accept my times. For the duration, I have just made two separate rules. Minor annoyance, but so far this is the only thing that seems buggy to me. And fwiw I am on Android, and using a Pixel 3.
@secondary_2g, I will absolutely pass that along. Thanks for your cents!
@kevinjdoherty1, I have the team looking into this issue now.
@brewmonkey, adding a device to multiple groups is on the wishlist… Hopefully it will be implemented one day.
Add same device to multiple groups (cameras)
