Introducing Wyze Solar Cam and Wyze Battery Cam - 10/20/2026
Introducing Wyze Battery Cam and Wyze Solar Cam :sun:
2K video, AI-powered person detection, color night vision, a built-in spotlight, two-way audio, and truly wire-free installation make it easy to keep an eye on what matters.
Wyze Battery Cam delivers flexible, mount-anywhere security. Wyze Solar Cam adds an integrated solar panel for maintenance-free charging, so you can spend less time swapping batteries and more time enjoying peace of mind.
Both cameras are IP65 weather-resistant and designed for quick, easy setup.
Learn more:
Wyze Solar Cam
Wyze Battery Cam
In Canada
Wyze Solar Cam (Canada)
Wyze Battery Cam (Canada)
Oh man the advertising for the solar cam states “no monthly trips up a ladder” and “maintenance free” so has wyze provided a way to press the reset button or power cycle a disconnect camera? - both common recommended actions. If not then at best this advertising is extremely misleading as pressing the reset button and power cycling the camera both require physical access to the camera which totally means dragging out the extension ladder and would seem to be the very definition of maintenance
This is just a re-imagined battery cam pro with 2k and the solar panel included. I already have 4 existing battery cam pro’s with solar panels connected. 2 of which solar panels are on extension poles mounted on my roof that are maximizing sun exposure and extending above the snow line.
Overall a decent improvement as for as cost is concerned from buying the BCP and solar panel separately and improved 2k video quality.
Not exactly a significant leap for introducing as a new product.
so I have 4 of the solar pan cams. What makes this new solar cam better? it just seems like a cheaper version. Why would you change?
This works for the Wyze BCP not just Ring. A better value for a 2pk with a 10% redeem discount currently on Amazon.
They did start to program some cameras to automatically reboot if they have been offline for so many minutes. This has been really helpful for a lot of people with basic low grade ISP default routers with memory leak issues.
How often do you have to restart your cameras? I haven’t had to do that with any Wyze cameras in years, like since 2021. I have over 80 Wyze cameras now. Every model they’ve ever except the V1. I haven’t had to manually restart them in many years now since I got a decent ISP and router system (ubiquity unifi dream machine SE with 4 U7 Pro APs). What kind of ISP and routers are you using? Maybe we can figure out what’s causing the memory leaks to require restarting the cameras so often,
Regardless of the cause, yes, most Wyze cams will now auto restart if they lose connectivity for to long. This helps force a new handshake connection with the router that rejected its persistent connection attempts. It’s been working pretty well for the people who need it. Have you had to manually press the test button lately? What model was it? Was it due to a temporary firmware bug or something? Unfortunately there’s no way around manual touching in that case.
Good question. I think it’s mostly cheaper and for people who don’t need a panning version because the fixed in place version already sees everything they need/want. But the panning version will be a better option for those who want it to pan.
I’m actually going to use both. I have one spot where I didn’t want the camera to pan, so the extra cost of panning is wasteful for that use case when I wouldn’t use it to pan anyway. I’d rather save the money. But another spot I use it to pan and definitely want panning.
I think Wyze needs to rethink making every single thing they have 5 times (doorbell, scale, door lock, cameras) just to fill in a small feature gap that the previous model didn’t have.
I understand what Wyze is doing in terms of a static/solar charged camera with a good price point. But these iterations of their devices are coming out so close to one another, that it seems really pointless?
But, I don’t run my own company so what do I know? Maybe I’m missing something?
Seems like Wyze week this year is a dud.
Don’t think the slot for the SD card on top of the camera is a good idea, there are enough post on the forum about SD cards not working (for some users).
laughing
I believe it’s on the bottom. The light is at the top of the camera in all the other pictures.
This picture is just thrown off because you can read the lens specs right-side up.
It better be on the bottom. :grin:
Probably put that one together backwards. :upside_down_face:
I’m reasonably confident it’s an AI generation artifact. It is the bottom of the camera (where the SD card goes), but because the AI put the camera upside down, and that particular wording on the lens is at the bottom of the camera, but some AI image generators don’t do a good job at putting text upside down or mirrored, so even though it knew it was the bottom of the camera that was facing up in order to put the SD card in it, it wrote the wording on the lens right side up. This is not uncommon with some generation tools.
Nice catch though. Whoever their graphic designer is didn’t catch the image text orientation glitch. That’s kind of funny. It got the position correct, just not the direction the letters and numbers should be going.
:rofl:
:index_pointing_up: This implies that the new Cam actually has user-swappable batteries, but other documentation describes this as having a “built-in battery”, so this statement seem potentially misleading, as it doesn’t use the same battery pack as something like Battery Cam Pro. That might confuse some users.
Take a look at the Wyze Troubleshooting information, Power cycling cameras is a standard recommendation and having to haul out the extension ladder / climb a tree or access difficult to reach locations for a camera that is advertised as requiring “no monthly trips up a ladder” and “maintenance free” is pretty much a class action waiting to happen. Maybe Wyze Marketing needs to run their copy past Wyze Legal before making these claims
No definitive response on if the battery is swappable or not and if so, when will Wyze make them available. Is this considered a single use cam once the 5200mah battery will no longer charge? What is considered the charging life cycle of the battery? At least with the BCP the battery is replaceable and prolongs the life span of the cam with it connected to a solar panel.
  1. Mount: Install 7–10 feet high, angle 30° downward and tighten. (As directions show)
    A six foot step ladder is easier.
    :laughing:
I can answer this because I got one I can look at. It’s not made to be swappable. It is fully enclosed and locked in.
I’m sure some people will do a DIY battery replacement in a few years when the batteries wear out as happens with all batteries, but these don’t have a door you can open like the Battery Cam Pro models. You would have to open up the camera (risking damaging the water resistance sealing) and manually remove and replace the battery with a generic one, then reassemble and seal it back up.
Worst case scenario, if the battery wears out in a few years, you could stop using it as a solar camera and switch to use it as an always-wired camera instead. It does work plugged in.
If that is a concern, then the Battery Cam Pro is a better option. :+1:
Thank you for the quick response and putting a period to the questions regarding this concern.
