Integrate facial recognition with nest hub
Once Wyze fixes the google nest hub integration they should integrate the facial recognition with the nest hub, just like it works on the nest cameras.
“Wyze recognizes face > announces name on nest hub and shows video feed” (like nest)
This is now possible with google allowing other companies to use nest features rather then them being exclusive like they used to be.
PS: When the google integration is finally fixed this post should be added to the #wishlist
You should add it now!
Maybe the @mods can move it.
I hope the mods can do it, it won’t let me now
@mods can you add this to the wishlist please?
[Mod Note] Your topic has been moved to the #wishlist as requested. You can VOTE for it at the top-left.
