An update that I also posted over on:
And see:
I have been experimenting with a couple 3rd party apps as a workaround. I am using both these apps currently in testing with great results. One of these is also posted above, sorry for the duplication.
I do not know if either of these have iOS counterparts as I am Androidian.
I originally used the app Free Notification Reader to force the phone to audibly speak my Wyze Notifications over the speaker or BT Headset. I could also customize the preamble to every notification to say âAlertâ or âAttentionâ or whatever I wanted. Because of the Notification Tone being limited to one tone for all Wyze Notifications in the Android App Notification settings, I customized that to the Jetsonâs tune although Free Notifications Reader can do that as well through the app.
Every time any of my 12 cams sends a notification, I would hear the Jetsons Tune followed by âAlert. Person Detected on camname Cam at 1:02pm. Check out the event videoâ. So, I audibly heard a) what was detected, b) what cam detected it and c) when. However, if this was on the phone speaker, it could get a bit annoying and wordy.
Another user in the forum introduced me to an app called MacroDroid. This app gives me the ability to set a custom notification sound for each and every one of my individual cams.
Setting up a macro for each cam was super easy. For my Garage Cam, I tell the macro to watch for any notification containing the words âGarage Camâ and to play a custom tone from my ringtone library when it comes in. Since the number of tones I have is limited by only the number I want to download, it is limitless. 100 cams = 100 tones. Or record your own. And, it isnât limited to cams. Any notification from Wyze, so long as it states the device name, can be set for a custom tone. And thatâs not all. It can trigger the phone to vibrate, flash the LED, open the app, send a SMS Text, send an email, send a tweet, trigger another app to do something, tons of action options (see the screenshot list below)
With these two apps working together, I have shut off my Android setting Jetsonâs tone for Wyze notifications because the MacroDroid tone will play at the same time and they will walk on each other.
I have the Free Notifications Reader set to only read when my BT headset is connected (driving) so it only reads in my ear, not out loud on the speaker (although it would probably work on a BT car link, I donât have that BC I prefer old beaters). It plays the MacroDroid device specific tone (not limited to cams⌠ANY Wyze device) then I have a 1 second delay set to read the notification on my BT headset so the tone stops first. When I am on phone speaker, all I hear is the MacroDroid set tone for whatever device triggered the notification (cam, contact sensor, motion sensor, leak detector, HMS alarm, Thermostat⌠ANY Wyze IoT device that can send a notification).
Here are links to the apps if you are interested. Free Notification Reader is free and without ads:
MacroDroid is has a free version limited to 5 macros with ads. Pro version is $5.99
