Improving the wifi range on for remote cam
So I was having problems with one cam at the far end of the garage as it had a very weak wifi signal. The problem was so serious that it would frequently time out when trying to access any settings. I had an old wifi repeater and I set it up to work with the offending cam and it solved the problem nicely. Now the cam is as responsive as the others even though it’s on its own.
