Router is a dual band Netgear , 2.4 and 5GHz are the same password .
I set the Cam up With my phone Loged into 2.4ghz Then switched it Over too 5ghz , Everything works fine And works fine on a tablet with 5ghz also.
Your cameras are still using 2.4GHz wifi to communicate with the router.
That’s what I thought might be the case .
That’s good , everything else I do on the phone and tablet is using the 5g speed
If you think about it, that’s really no different than if your phone is on a wifi far from home. However, as long as both cameras and phone are on the same local network (even if connected to it through different wifi speeds), the traffic will stay local without using ISP data.
