I’m really frustrated. The same thing happens to me now, they stop working out of nowhere and it’s not my Wi-Fi because I have a Wyze Pan v3 camera and it works perfectly. But this is garbage Wyze Cam Floodlight v2 It seems to stop working and the worst part is that the last camera was barely 1 week old. I’m frustrated ![]()
Context? What’s the “same thing”?
I’m having the same problems. Very poor design. Has anyone figured out how to replace the V2 camera in it with a V4
by same thing, it just stops working and going offline but the other cameras in its vicinity use the same wifi and they are working.
FWIW, one of my floodlight V2s had a problem today. It was very slow to connect and failed to show its live view most of the time. Cloud clips won’t load. From previous experience with other Wyze cameras, I suspected the SD card was full. And it was. Formatting fixed it.
In the past, a full SD card wasn’t an issue. But it looks like it is now.
I already solved it, it’s a problem with a WPS PIN that comes activated by default on your gateway or commonly called router.
You have to enter your router on the web and go to gateway and then to connection and then below it says wps security something like that enter there and deactivate that and try to connect the camera from scratch And it worked, in my case it did using Xfinity internet.
