If I purchase the Wyze Home Monitoring annual subscription, will I be sent any hardware?
Will wyze be sending me anything hardware wise after i purchase annual home monitoring subscription or am i just paying to unlock the service? (i have wyze cams already)
Just wanna make sure
If you are only purchasing a subscription, you won’t get any hardware with that subscription purchase. The Home Monitoring Service requires the Wyze Sense Hub and Wyze Sense Sensors. Cam Protect, on the other hand, uses Wyze Cams to monitor.
If you already have a Wyze Sense Hub and the Wyze Sense Sensors, the subscription purchase will allow you to setup the Home Monitoring settings within the Monitoring Tab provided you have the Sense Hub and Sensors installed to your account.
If you don’t have any hardware, those will need to be purchased. If this is the case, it would be best to purchase them together with the subscription since there are bundled pricing discounts when you purchase.
