This would be a perfect replacement for my current router, except I need the additional LAN ports for my network setup. 4 LAN ports would be good, in my opinion. Thanks!
[Mod Edit]:Title and tags modified to be more inclusive and to enhance search clarity.
Adding 2 additional Ethernet ports to the already designed and marketed Mesh Router will neccessitate a product redesign. Therefore, your wishlist submission has been changed to a compilation topic that covers user ideas for a next generation (v2) Mesh Router.
8 port gigabit switch switch. Problem solved. No need to make the router more expensive, generating more heat and using more processor/RAM, etc, for the people who don’t need more than 2…
Allow the Wyze Mesh routers to be powered via POE (Power over Ethernet).
This would allow the APs to be easily placed where wi-fi is needed (not in my IT closet) while taking full advantage of wired backhaul already offered.
There are lots of POE adapters, so it might work to use those.
I have noticed that it’s rare for any routers to support being powered by POE which makes me think that POE doesn’t generate enough power to do this well especially since the power will continually degrade the longer the cord is.
It would be nice to have more flexibility and fewer cords if it is possible effective.
Oh, it doesn’t just use the regular ethernet ports? I’ve never used PoE yet, so I just assumed it used any Ethernet port. Does it have to have a special port for it to power other devices?
I’d like to see both (all, if more than 2) ports on the Pro version be 2.5G or better, rather than just the WAN port.
I currently have 1.5Gbps internet, and my new computers have 2.5G ethernet ports for fast access to internet as well as local LAN data (on my NAS), so I can’t take full advantage of my high-speed internet connection and faster local network connection with the 2.5G WAN + 1G LAN ports on the current Pro router.
1 WAN Port
1 10 2.5gbps Backhaul Port
4 LAN Ports 1 Gig are a must to be competitive with other wireless routers on the market place
I strongly recommend 6 to be fully helpful, increase density, encourage wired connections, and reduce the need for external switches or other equipment
Has anyone received a Router or Router Pro yet?
I’m confused about the coverage -
If it covers 2,000 sq ft that is about equivalent to a circle 65 feet in diameter, that seems pretty limited.
Why, sir? You need POE, with only one port coming off the router? Add a POE supported switch coming off the router. Save increasing the expense to all on the router to satisfy POE for a few people.
The request is to have the router powered by POE, not provide POE. This allows the router placement without an electrical outlet. Same for additional nodes in the mesh.
