After at least 3 years of using a Pan cam outside it finally died.
I had it in a silicone skin but water managed to climb up the cord into the USB connector.
Not bad for a camera that wasn’t designed to take the elements.
May Pan Cam Rest in Peace !
But wait !
Some Wyze Tinker, might know how to save her ?
Any takers ?
Ida’s name should def. Be Retired !
If Ida known you were coming…
Booooooo
pan cam pun panned
Nope, nope, nope…
and I was so sure you were posting her
Hard sell, eh?
I had a v2 slung under a window ac housing in an especially driving rain, no special protection. It failed, short-term, but I shook it out and put it in my cotton sock drawer for a couple of months then it was right back to work. Quite a trooper.
I haven’t thrown it away. I’ll give it a few days and try it again.
Ida thought you would…
Well Ida hands are the devil’s workshop.
Lest we be accused of Idalatry:
Wizened ex-hubby, Howard Duff, from hell:
My own private Ida ho.
Hey!
“Wur’s da RimShot !”
Wah, wah !
It’s that sound in our head that no one else hears.
I had the same thing happen to my pan cam, just not due to Ida. I opened it up, dried it out for a week, looked for any rust or corrosion, and after putting it back together it worked just fine!
Put it in Silica Gel Desiccant Beads to dry it out.
Use Dielectric grease to seal out moisture to begin with.
Your Welcome
