I want to turn off my living room light when no one in the living room more than 10 minutes.
How can I set that?
You would need a motion sensor.
Create a trigger rule for the motion sensor that says “When has been clear for” 10 minutes, turn off the device that controls power to your light (Wyze Bulb, Plug, or Switch).
This may not work as intended unless someone moves enough to set off motion every 10 minutes, though. You may want to extend that time to 30 minutes?
