How to reset Wyze Montion Sensor (after sevral fail attempts)
I setup Wyze Motion Sensor attached to one camera,
and after a day it shows loose connection.
So i remove the devise from my account and try to re install by follows procedure.
Press the pin and wait red light blink 3 times but fail to connect.
Pls tell me how can i reset the other means .
Thanks
https://support.wyzecam.com/hc/en-us/articles/360025999952-Wyze-Sense-Troubleshooting-Guide
thank you my problem solved after take out and put it back the battery.
