How do we turn off two factor on our account, I log in several time from work on my desktop an dalways asked and getting old?
Are you talking about the Live Web View from a Desktop?
I believe you do it from the App at this time.
You would go to the App, select Account>Security>Two-Factor Authentication
Then at the bottom you would have to turn it off. As you may be aware, turning off 2FA is not recommended.
However, I am not sure if Live Web View require 2FA, I will check on this.
thats perfect… thankyou
No Problem. Glad it worked for you.
