I would like my cam v3 that’s in a wyze socket to auto turn on at night, similar to the “detect motion” setting, except i want it to only turn on when it detects a person. How do I go about this?
You can create a rule to do this
Is there a guide to creating that rule set?
I feel like this should be just a standard option.
You can create a rule using the + on the Home Screen > add rule. Create a new rule with the trigger of detects person and action of turn on lamp socket for.
You can then define the amount of time the light will be on before turning off.
Make sure you disable the auto feature in the lamp socket settings.
