I added some cameras and can’t figure out how to add them to the Away and Home rules I made. Is there a way to do this?
If your existing rules apply to cam groups and you already added your new cams to those groups, you’re good to go.
If not, just edit the existing rule(s) by going to Home > Edit Rules (pencil icon in upper right corner) > click on the desired existing rule > Add Action (the “+” symbol on the right) > then select your new cam(s) from the DEVICE ACTIONS section > checkmark the box next to the desired action for the new cam > Save
Thanks!
I’m pretty tech savvy but the app isn’t very intuitive.
Glad to be of help.
