How to delete Wyze mesh router pro from app?
There is no Delete Device option for Wyze mesh router pro in the app. Any idea?
There are two areas to do this.
  1. you can go into the Mesh router, Select the gear at the Top Right, Choose Advanced Settings, the select Factory Defaults. After doing this, it should remove it from your list, If not, follow step 2 below.
  2. On the Home screen, tap on the Pencil in the top right of the app, Select Edit Devices, then tap on the - sign to the left of the router. Note: If you use this method, you will need to manually reset each router and node so that your information has been removed.
Curious though, is there a reason you are wanting to remove them? Are you experiencing any issues?
