Hi, is there a way to all of my Wyze camera v3 to my current NVR to add to all other IP cameras on this device for viewing in one location?
Welcome @fenmrks
Currently there is no real way to get them added to your NVR. However, you can use any of the following:
https://my.wyze.com This is the Wyze Portal which will stream those cameras containing Cam Plus. Note, I have successfully set up a WebBrowser on my GoogleTV device and connected to the portal and can now use my TV as a big monitor streaming all of my cameras
You can use Tiny Cam and attach the cameras to that as well.
There are other options for streaming with Home Assistant as well.
