How much space does wyze beta app consume on phone?
WyzeBeta is shown as occupying 1.79GB on my phone (Samsung A20) list of apps.
It shows 1.44GB used for data with my SD card dismounted.
I’ve put all my movies etc onto the SD card and looked all over for other “hidden” data.
IF I delete the app and reload the app will it still work?
Thanks.
Guess I’ll try to clear data and see if that works,
That may do it. Not sure why mine is taking up significantly less space. Let me check some of my other Android devices running beta…
Checked phones and tablets running beta under Android 8, 9, 10, 11 and 12. Checked with app running in background and also killed. All are around 500MB except one using 1GB.
