How many plug schedules
As the subject says. I need an off/on schedule once each hour for every hour per day. Can the Wyse plug have 24 schedules?
Thanks
Don
Try it and find out - and then post your results…
Welcome to the User Community Forum @bbnd!
If the plug on\off time schedule is exactly the same for every hour, you only need 1 Device Trigger Rule.
If Plug is Off for 45 min – Turn Plug On for 15 min.
Just modify the off\on time to = 60
You can also constrain this rule to only run between specific hours if needed.
Thanks Slab, that is perfect.
Glad I could help!
